Problem on my GSR
muskasim
To all out there whether face this kind of problem or not. My car running on GSR 4G93T and everything still standard. SO... this is what nomally people do... turn the ignition key to start position and then wait the check engine light turn off then start the engine... this only takes 3 to 4 second, right??? My problem is the check engine and the boost light indicator cannot turn off everytime when my car didn't start for long time i.e. 24 hours, this will caused the engine cannot start. After 4 to 5 minutes the check engine and the boost indicator light turn off itself then back to normal condition.
So... anyone can help me out there.
hi muskasim,
i suspect your have a near faulty relay or wirings. Intermittent problems are very difficult to solve. The relay I'm talking about is usually located behind your CD-Player (the dashboard) check the connection for any corrosion. The other worst part is your ECU. it may be short-circuit or having a leaky capacitor. Next to check is your air-flow wires connection, however, if this connection is faulty.. the turbo indicator light should not be 'ON' only the check engine indicator is. good luck~
Already changed the relay behind the CD player (Gold colour) on the right side of the "tiang"..... but problem remained.
Sorry it should be on the left...not right.
hmm.. try swapping a workable ECU and see how it goes...(make sure u properly ground the ECU) if u are using 5663 ECU use back the same model, likewise if u are using 7377 If the problem remains.. have your wires and fuses re-checked.
Maybe this is the only way, anyway thanks alot. But now donno where to get the ECU.... or maybe u can borrow yours.... just joke lar. If no other way I'll try to approach the CAP inside the ECU.... I heard before the CAP may cause problem also.
Suggest get someone with something like MUT to diagnose the error.
if you cant get aanyone, call me 019-2499509...got a friend who own this unit
Ur place too far from Penang leh..... I just change those capacitors inside the ECU yesterday but it doesn't help. :(
5663 ler.. if u wan to meet up gimme a ring la ok? saturday or sunday only free to test your ECU... or best if saturday time go to my mech place and check.
Problem solved, contact problem in the ECU.... just sprayed with contact cleaner to the ECU printed curcuit board and dry it with air gun.
it took u months to get it settled?? apa la.. say wanna come meet me.. apa jadi woi? u know acaria auto accessories in seb.jaya? i usually go lepak there with my fren.. Satria GSR.
ezwong2002,
acaria auto accessories ?? in Bandar Sunway?? What's hapen to your car.... use back the original hood and take out the sparco seats???
