Sifu's out there...help needed...my ECU always hangs and the car can't start. The "check engine" will go off but the "turbine" spool indicator will cont to light up then the car can't start. Already 2 times in 3 months....help plsss.....I'm using 5663 on gsr.
simple and easy, format and reinstall all over again, if you need drivers such as brake, turbo, aircond, try do a search on the net and download to your car...
GSR-SAM ... check the specific sensor ..replace if needed.
Please have a time to go thru this, u may find something:
- http://www.mr2.com/DIGEST/VOLUME2/3217.txt
- http://www.turbobricks.org/forums/archive/index.php/t-36461.html
