problems on my engine vacuums
mrevo
I'm driving wira with 4g93t engine. Nowadays my engine RPM is very late to turn down when I rev the engine, seems like the throttle body late to close. the boost meter also late to turn down. anybody knows what happened?
I checked the vacuum hoses but no leaking/cracking. Normally, if vacuum hoses leak...the vacum will drop and make the engine RPM unstable.
If comfirmed not vacuum leakage, just check on ur TPS.
maybe need to recalibrate.
hope can help. Thx.:nurse:
ok ....how about ur buterfly throttle....clean it....or cek ur fuel setting or cek motor oil....or cluth
Thank's to all, the prob is already solved. Actualy, the T joint that jointing the vacuum hoses fro TB, BOV and boost meter was melted and blocked the vacuum towards the boost meter. Now, the acceleration is smooth also can boosting as well.
