Problem with engine
Hello frenz,
I have some problem with my car engine. :hmmmm:
It will jerk/turn off while still moving when I press the clutch to shift from high gear to low gear and when slow down at trafic light. It happen quite frequent unless if I keep on accelerating the engine. This only happen when I turn on the aircond.
Fyi, I'm using engine Silvertop 20V that fix into toyota AE111.
Appreciate your help/idea on how to solve this problem.
Thank you.
try checking the intake hose between the throttle plenum & the AFM sensor.. mayb its broken (got holes)
i have similar problem with the same engine.. just change the hose & u'll solve the problem..
