how to adjust your headlights
EG8
2,000 RPM
Aiming Headlights Or, how to maximize visibility without blinding other drivers By: Tom Morr/autoMedia.com
Causes | Back To Top
Headlights can become misaligned in many ways. One of the most common is when the person replacing a bad light inadvertently turns the adjusting screws instead of the retaining fasteners. Fender-benders and other front-end damage can also cause lights to become askew, as can carrying heavy loads in the rear quarters (which is why several upscale SUVs now have automatic load-leveling suspension systems).
Many repair shops will check and adjust headlights for a modest fee. However, the process is straightforward enough that the average do-it-yourselfer can save both time and money by following the steps shown here. Although special products are made specifically for correct headlight aiming, the method here doesn't require any proprietary know-how or materials—just masking tape, a tape measure and a screwdriver. Incidentally, most repair manuals recommend checking headlight adjustment every 12 months and any time a lamp is replaced or front-end damage occurs.
Step 1
http://www.advanceautoparts.com/english/youcan/images/ccr/ccr20010801ha/ccr20010801ha_s01.jpg
Begin by finding a level surface and a vertical garage door or wall. Park the vehicle close to the wall and mark the lights' horizontal centerlines with masking tape.
Step 2
http://www.advanceautoparts.com/english/youcan/images/ccr/ccr20010801ha/ccr20010801ha_s02.jpg
Next, mark the low beams' vertical centerlines. For better precision, stand behind the car at its center point and, looking through the back window, guide a helper in marking vertical dead center. Marking the vehicle's centerline is also helpful to verify side-to-side alignment.
Step 3
http://www.advanceautoparts.com/english/youcan/images/ccr/ccr20010801ha/ccr20010801ha_s03.jpg
Park the vehicle on a flat surface 25 feet away from the wall, pointing straight ahead. Use the lights' horizontal- and vertical-adjusting screws to position the low beams' intensity zones two inches below and to the right of the taped centerlines. (Trim ring removed to show adjusters.)
Step 4
http://www.advanceautoparts.com/english/youcan/images/ccr/ccr20010801ha/ccr20010801ha_s04.jpg
Adjustments can normally be made without removing any parts. Turning the top adjusting screw clockwise raises the beam and vice versa. Similarly, the side adjuster moves the beam left and right.
Step 5
http://www.advanceautoparts.com/english/youcan/images/ccr/ccr20010801ha/ccr20010801ha_s05.jpg
High beams' "zones" should be below the line and vertically centered in relation to the vehicle's centerline (not marked with tape in this example). Here, the right-side high beam needs to come inboard. When in doubt, be courteous and err your aim low and to the right.
http://www.advanceautoparts.com/english/youcan/html/ccr/ccr20010801ha.html#
saga cannot do like that one ler...headlamp cover comes fixed, and stock headlamps point a max of 10 feet nia >.< interesting article anyways..
k3vin, my saga can adjust. You will notice a philips screw head on the headlamp (mine is white). That is suppose to 'shift' the headlights...i tried it before, but too little difference. Design problem from Proton....
