DIY-Gen 2 Front Headlight Low Beam Bulb Replacement
ayen_s
Proton Gen 2 Front Position Headlight Bulb Replacement
http://farm5.static.flickr.com/4077/4806999299_0f4f637b4f_m.jpg
Tool:
1.Multimeter - 1 unit (for testing)
2.Replacement bulb- 1 unit
Duration: 15-20 minute
Procedure
1. Open up the front hood of your car.
2. Reach your hand to the back of the head light.
3. The low beam head light is at the lower part.
http://farm5.static.flickr.com/4078/4807621756_750f812e37.jpg
4. Twist the bulb socket counter clock wise to release it.
5. Take out the bulb socket from its slot.
http://farm5.static.flickr.com/4138/4806998699_f5c76f723d.jpg
6. Pull the burned bulb from the socket.
http://farm5.static.flickr.com/4100/4806998401_7e8e12e599.jpg
Note you can check the continuity of the bulb terminal to ensure the bulb is faulty. No continuity means the filament is broken.
It it black as in picture, confirm to replace it.
7. Install the new bulb to the socket and put back the socket in to the slot.
8. Twist the socket clock wise to lock into its place.
9. Turn on the car light to test.
10. Finish
UPDATED
-The bulb was wrongly identified as the low beam. Its actually the procedure for position light.
sori 4 asking...
last time i change my waja bulb by myself...
the prob now i cant ejast hi lo beam after that...
only ejas manualy by pull it behind not using screw driver tu pusing2 that ejaster...
mb at the time i want to push pin out that thing gone front n mb loose the place...
so anyone please help... beside change to new one what else i can do... thanx...
mottrang....did u turn the screw until it just cant adjust anymore? even reverse the adjustment also cant move?
the adjuster is just basically a fixed screw with a plastic nut connected to the reflector bowl...if u turn too much, either the plastic nut came off the screw or reached the end of the screw n wore off...if really turn n no movement...u have to open the headlamp cover to take a look see. happened to me twice. tried changing to a metal nut but it seems they use a non standard size screw. in the end, i put some 2 tonne epoxy inside the plastic nut (just lightly coat the insides to add material so the screw has more material to dig into) n covered back the headlamp...hard to imagine...but once u open n take a look you'll understand.
nope... jes turn a few time till my hand lenguh but nothing change... :bawling:
btw thanx for the explanation... i will look for it when i am free... huhu
only jes wanna know how to open it... what i can see is only got 3 skru... 2 at the same line with radiator panel 1 down near that air box... got any else...
