How to Spray paint Your Car
reedoor
2,000 RPM
spray ur car urself?! hope its a nice link... :_:
http://www.psychopanic.com/spraypaintcar.php
How to turn your car from this:
to THIS!!
And then...............................................
Easy - I just grabbed my magic wand and VOILA! (no I didn't - this took me two days of hell - however it was worth the effort!)
Instructions:
You need the following materials before you begin your quest to change the colour of your car:
(most materials are in the below photo)
*Prices are in Australian Dollars as of March 2005
Ingredients: (amounts etc may vary for smaller, bigger or different cars)​
  • 4 Litres of K&H Surface Primer Filler $53.65
  • 3 Litres of Super Velox Q.D Agricultural Enamel (in your colour) $77.10
  • 250ml of U-Add Enamel Hardener $30.35
  • 4 Litres of Multilac Thinner $18.50
  • 5 Pieces of 80Grit Wet/Dry Sandpaper (more smooth if preferred) $5
  • 2 Rolls of 18mm x 50m Good Masking Tape $4
  • 1 Goggles & Filter Mask Pack 2Pc Set $4
  • 1 Roll of Contact Paper ~$2 (I already had some)
  • 1 Stanley Knife $2
  • 1 Pair of Ear Plugs (if you have a super loud compressor) $0.60
  • 1 GMC Air Compressor $100 (however I borrowed my friend's one)
  • 1 Hose to connect compressor to spraygun $25
  • 1 Spraygun to Hose connector $7
  • 1 High Pressure SprayGun $50 (the most important tool you need!)
  • 1 Sander $25 (very handy or if you are lazy - not absolutely necessary)
  • Lots of newspaper (to cover your windows etc. with) Free - buy the paper!
  • Need Liquid measuring cups as well
  • TOTAL cost $404.20 (to save costs i hope you have friends with some of this equipment that you can borrow for mates rates)
Ok, now it is firstly advisable to park your car out of the sun, or under a carport like I did so that the weather elements don't affect your work (rain, hail & shine baby!)
Next, after you have cleaned your car free of dirt and grime and such, you have to do the boring task of taping all windows, handles, headlights etc with sandpaper so that your WHOLE car doesn't end up a new colour! Also, with my little car name label (ie. where it says Holden Astra SLE on my car), I covered that with contact paper and cut around it using the stanley knife. This task took me a whole FOUR HOURS (maybe I should have had someone help me do this oh well)
Next, this is where you have to use the Primer/Filler stuff. Get your spraygun out, mix 3 parts of Primer and 1 part of thinner, and spray the entire car (don't be concerned if the spray doesn't come out very well).
This is the air compressor that I used (I borrowed this and the hose came with it too)
After you spray the first coat of primer on, wait for about an hour or so (I waited overnight because it took me the whole day to do all the above steps), then you can sand down your car. Repeat this step twice (ie. you need two coats of primer, and sand down the car after each coat). However, because I was just lazy, I didn't sand back ALL the primer down, the only important thing is that the surface of the car is smooth after you sand it.
Final step - After you sand the primer coat down, clean your car of all the dust and grime etc. (to make this easier, I just used the spraygun as an airgun to blow all the dust off the car). Now the FUN PART - when your car is free of dust, mix the 3L of Enamel paint with the whole 250ml tin of Enamel Hardener and put around 300-400ml of Thinner together (just enough thinner so that the paint is sprayable). Now, this is where you need the filter mask - you are working with 2Pack Paint here, so breathing it in is quite a bad thing! Get your spraygun, connect it up to the compressor, and spray two coats of paint on the whole car (wait about 10 to 15 minutes between each coat). **I got told later that I need a clear top coat, but I didn't have the top coat stuff, so too bad**
After the car is dry (I would wait at least two or three hours), it is time to take all the newspaper and masking tape off your car and WALLA! TADAAAA! you are DONE! Just take a good look at all the work you have done and be proud!
All this work took me two long 8hr days of hard work - and believe me - when you are finished, it is well worth the money! I have added years of life to my car presentation wise! Now the cops won't pull your rustbucket over all the time! Oh yeah, I didn't photoshop the number plates above that seem to be a holy bright message from god - it was just my camera that did that! Also, as a touchup, you should put some cut n' polish on the car as well to smooth the layers out!
Carnauba Polish, 240mm buffer, polishing buff (left), polishing cloth (right)
** I just bought myself a 240mm diameter buffer. It has a variable speed on it, and it was only $48 from Super Cheap Auto. I could have gotten the more expensive and smaller $150 one, but I couldn't afford it, so big and cheap will do me instead. I just buffed my car, and it looks pretty good considering that I did it at night with only one spotlight.
To use the buffer - first put the polishing cloth cover on the buffer tightly, then put some of the carnauba polish on the cloth and then use the buffer all over the paintwork (keep applying the polish when it runs out on the paintwork). When you have polished the car, put the lambswool/polishing buff cover on, and then use the buffer all over the paintwork just like you did with the cloth. That's all you should have to do to make your car shiny, clean and AWESOME looking!
THE END!! ENJOY YOUR BRAND NEW LOOKING CAR!​
Wow..good information there especially on the material needed and how much to mix the harddern and the paint.....
If only i have the tools and area and time.... hahha......
Really interesting , if we know where to buy all the stuffs ...
But come to think of it, my neighbours might curse me to hell.
Hahahaha!
hahaha... spray car need to be in an enclosed area lo.. later got wind blow sand and leaves on to undried paint cialat lo....
besides, if spray in open area, the paint will fly to next door... kena marah from neighbour lagi.... haha..
need a workshop to do it properly lo if wanna spray whole car....
in Malaysia someone is selling spray gun and compressor ma... small one ... for spray paint car art... RM250 i think...
yea, his shop is somewhere at cheras area i think........ but the paint is like rm60 per liter and one whole car roughly need 4 liters and 2 liter of clear coat and few liters of primer....... ? :D
haha everywhere also can get compressor.. cheap 1 from RM 200 to RM 500, compressor does not matter, most imporant is that GUN that u using.. dont every buy the RM 50 bucks one.. waste money.. get the best that u can afford.. about RM 100, coz. better = more fine particles = better coating, and,.. auto paints can be aquire at.. most of the places... about Rm 90 each liters i think.. if u wan metalic effect! buy the shiny gold dust thing and mix into ur paints.
i learn all this by... watching some set builder do their set for advertismetn.. ^^
well.. location wise... if can get a consealed place its the best.. if cant... buy some " kok-chai "make a frame, buy canvas about RM 100 for a HUGE one, build it.. get some 250w spot light, to shine into ur car while u do the job, inhaler mask to keep u alive.. and.. thats about it.. u get the almost similar effect as the BAKED paint.. just not so effective.. got the rought cost of things to paint ur own car
compressor RM 250
air gun RM 100
Paints RM 300 ( everything)
other nonsense Rm 150.
TOTAL RM 800 -__-
might as well just send to shop ask them paint for u for RM 900 or less... if u are lazy.. hahahah
1st - use filling putty then sand it down
2nd - use primer
3rd - then color spray
4th - clear coat
is it correct? 1,2,3,4 step are repeated rite.
what type of sand paper i should buy?
done that to my bug after involved in some minor accident..use 3 liters of autocolor car paint for one car..two coat..primer is standard metal primer..
use 3 grades of sand paper 600, 800, 1000 (if im not mistaken)..and no clear coat
already got compressor and spray gun..sand the whole car first, then basuh, dry it n spray primer, dry it, sand it again (i used wet sanding), then spray 1st coat, then 2nd one, then walla..finish..
pros- cost around rm500 (paints, spray gun, sand paper, tapes, and stuff) really cheap
cons- not so tidy (a abit lazy to tape the paper properly), time consuming, collect dirts a lot..
the moral of this DIY session - surface prep. is super duper important, make sure the area is properly close so there's no wind blowing right where u r working, be patient..
2 cents..
waa..600-1000 grit? u sure? most sites i read is like 80-200grit.
do i need to put fill putty before sanding? should i sand the car with buying a sand paper or the machine one?
i use taht becos i just want to change the colour onli..i didnt strip the ori color..so just use 600 grit to scratch the old surface and then tembak primer..
IMHO, the sites suggest u to sand the surface till u can see the bare metal..its better if u done that so u have a smoother finish at the end..
use putty to fill any gaps causes by dents or rust..if u want a good hand exercise..then u can sand the car by hand..
for me, the project is my first experiment on DIY painting..got a lot of knowledge from it..and if u have time, and can be ultra patient, buy a paint stripper, strip the old paint, then put primer (one or two coats according to your preferences), sand it each time u done a coat,then spray 2 to 4 layers of paint (again according to your taste), then put clear coat..
again, make sure u have a controlled surrounding (wind especially become a major factor) and be extra patient when doing it..
