previously I've wrapped my extractor with heat-wraps, but noticed my engine temp gone a bit higher especially during stops at traffic light or jam, and the cooling fan works longer than usual. And these happen right after I wrap. You guys with heat-wrapped extractor don't experience this?
If you have...
I later added another thicker layer of cutout paper gasket to the existing extractor gasket (think is now about 1-1.2mm thick) and the temp problem reduced (not 100% solved).
EDIT ADD : that was with previous extractor, now changed to other, unwrapped but applied 1.0mm gasket. Engine temp normal even while stopping idle for a long period of time.
If you have...
