[DIY] How to decrease engine bay temperature
good point stated there, so far, i can't find any articles that say silicon spray will vaporized..
but it definitely worth a thinker..
on what is a silicon spray:
Thanks for the link but don't answer your question....:smokin:
Yup, trying to find out what silicone spray too. If those lubricating silicone spray, I don't think it can stand exhaust pipe temperature and will just vaporized....
---------- Post added at 08:17 AM ---------- 6 hour anti-bump limit - Previous post was at 08:16 AM ----------
When doing it?:driver:
Probably next weekend. 1st Nov weekend
wow, thanks for sharing.
i just realize Johor don't have Ace hardware... :confused:
guess i have to shop around in singapore
I bought one bottle for think less than SGD20.. go jurong point there downstairs.. opposite the Samsung shop there's a hardware shop.. I used mine for the base coat for my swift brakes before the yellow paint.. till now not even a single fade for the yellow colours, only some stone chips..
wow, thanks bro. :adore:
i went to ubi today to hunt for this paint can.. all never sell..
1 can should be enough for the whole header, i'm thinking of getting 2 can, spray the whole exhaust..
anyway, i saw a promo in autobacs, SGD10 for 3 can of silicon spray from soft99.
said to prevent moist, conditioning leather, rubber, engine and even tire.
it could also be applied on the windscreen..
not bad, i grab 6 cans at a go :proud:
ok, the shop that you referring is call selffix DIY, they have an outlet at tampines.
going over after work, SGD16 per can, got blue, black, silver
Yes, so tomoro you'll be at ken there?:smokin:
yeah, only a while.. need to go out and shop...
---------- Post added at 07:15 PM ---------- 6 hour anti-bump limit - Previous post was at 05:10 PM ----------
OK, update.
I Just bought my high temperature paint, blue color.
The paint should be waterproof right, I assume
OK, update.
Paint sure waterproof gua.
if my intention is to reduce the engine bay temperature, by directing CAI hose to somewhere near the exhaust manifold help?
currently using 4-2-1 SS extractor and have done lifted hood...wanna further decrease engine bay temp especially extractor area. (i know exhaust wrap is the best way but i need more budget for that)
atm wanna try out cheaper alternatives.... :)
Then it won't help your engine performance, taking in hot air....:banghead:
currently not using open-pod air filter...by putting CAI hose directing to the area between the radiator and the exhaust manifold.will it helps to direct cold air from front into that area? CAI hose take air from front from the foglamp hole.
concern and goal is to reduce temperature...i dont expect performance improvement.... :D
You will decrease the performance by taking in hot air. Now is taking in air from outside that is why it is located at your fog lamps...
Purpose CAI is to provide colder air for combustion. Colder extractor is not good, that why manufacture put a zink on top of the extractor to prevent it become colder.
Better you put CAI for air intake
Sent from my Galaxy Nexus
Yup, CAI already is Cold Air Intake.....:driver:
hmm..perhaps i can change plan to remove the stock drop-in air filter scoop and route it using CAI to the foglamp hole...
owh, u mean the layer of zink on the extractor? looks like the only best solution here is exhaust wrap already...
