Z zfaliz Nov 5, 2012 #1 i owned Wira 1.5se a/back. Recently i have problem with exhaust sensor and i have replaced it. The problem is after replaced exhaust sensor check engine light up when the rpm goes up 4000rpm. Does it effect my wira performance and how to solve it?
huakenny LB Performance Senior Member Nov 5, 2012 #3 diagnose and check the OBD code, check the said problem and erase the code test drive and check if the light come out again o not if yes, diagnose again if the OBD code appears to be the same
