Aircon problem
igor30
Boss..wanna know if aircon receiver spoilt/the switch which control the rpm ( usually on top of the receiver ) spolt means what happen ???I've been having this problem recently and it's soo sickening.The rpm will be soo inconsistant and it effect the temp too.I brought it to a/con shop n that fella change the switch ( 2nd hand ..new one is pretty costly ).The next day the same problem happened.I'm feeling sick as the car is sooo inferior to drive !!Whenehev I stop ( eg traffic light ) the RPM goes up n down..Plzzz help ..btw i'm drivin a Wira powered by carburator...
is the air cond slow adjust to too sensitive?
there is a screw to adjust how often the compressor kick in..try look for it..
tighten mean it will kick in longer time and more frequently
Yo bros..the problem is solved now..the root was the dirty condensor which effected the whole system to run in a very hot temp.Therefore the valve kick in/out unstopable..fthrmore if its a humid day..likewise I had it on the wednesday..My balls were shrunk to drive the car after work in Fed h/way..It was a freakin jam and very hot..the valve was soo restless..End up hv to drive w/out a/con :frown: .Anyway I brought it to the mech and the gut svc the a/con..change the condensor to the 1.6 model ( longer compare to wira is shorter )..and it cost me a whopping RM 5xx...Phewww..:rolleyes:
