Honda Stream Engine check lights on after replacing catalyst converter
nicollim
Hi, I have a 2003 Honda Stream, last June the engine check lights is on, and the error reading as exhaust deterioration, I then send it to exhaust sifu, they told me to replace the cat-con, to a normal stainless steel chrome piece. After they replace it they reset. But the lights came back on after a day. My car current mileage is 250k. I want to know, is it normal to change the cat-con?
Some told me is Oz censor problem, but where can i get the potong set for the 2 censor, cause the ori ones very expensive.
Who told u the error read as error deterioration?
i doubt the most expensive car wont have sensor to detect the exhaust has deteriorate,only sensor for exhaust temperature.
Best bet is to send it back to Honds to be diagnose and once u know he error just send it outside for repair.
much better than just changing this and that.
just ask around chop shop.needs patient and time.
Easy alternative is to ask spare part shop and if its still expensive to u then ask for alternative part which is compatible.
Yeah i send to Honda, they told me is cat-con problem but the quote is ridiculous high, they said if the oz censor problem the system will tell you bank 1 or bank 2 and what happen is the potong shop will not have ori used cat-con, even if they have they cant guarantee how good is the condition. My car is working perfectly in fact with more power now, but problem is i need to get rid of the check engine light, which i want to get a potong set.
bro try ur luck by calling AR MAN Auto at 03-4280 1031/019-600 3824.
i got my O2 sensor from him - halfcut condition.
