eraserwke said:the water expansion tank.. RHS when u're looking at the front of your car? Got this black box thing behind my left headlight. makes me can't reach the screw to adjust my headlight angle. my angle out already i think thats why my lights very dim at night. cannot see far.
DarkAccoon said:why larrr, everyone thinks the shorter the screw driver the easier it is to adjust the headlights
take long long ones
much more easier i assure you
after reading this i bet you will never use those short stubby screw drivers for headlight adjustment anymore
(referring to wira)
as you have already located the screws to adjust the height and width
here is what you do
look from the top and you will see those screws can actually be adjusted from the top
just plug the long screw driver into it and start adjusting larrr
dunnit to screw from the back of the headlights wan
eheheh
some lousy workshop taught me this (more like i curi listen to their conversation)
Supachip said:Water expansion tank is on the LHS if u look from in front of car, white color tank. Black box? I suppose u mean the fuse box. That shouldn't obstruct the light adjustment screw lah. Just use a stubby philip screw driver to adjust, if u using normal long screw driver of cause cannot. The screw of headlamp near to the fender is used to adjust the beam height and the one near radiator is used to adjust width of beam.
Come on, this is easy job lah brother, try again....
