DIY: Retrofit Projector lens into wira headlight
hhh
DIY: Retrofit Projector lens into WIRA/PERDANA headlight
Hi guys,
I had just retroffited a pair of bosch e46 projector into my wira head light.
pls check below for the pic of the projector that used for this DIY.
http://hid.com.my/forum/viewtopic.php?t=13
And guys,
Can anyone teach me how to upload the photos??
I like to upload the photo of my car with the projector light.
Thanks.
hhh said:
Hi guys,
And guys,
Thanks.
you might need to register an account at photobucket and upload your photo on it... then use the url and insert it in your post...
http:\\photobucket.com
Thanks tykoh.
pls refer to link below.
http://i42.photobucket.com/albums/e346/hhteo/P2270254.jpg
http://i42.photobucket.com/albums/e346/hhteo/P2280277.jpg
http://i42.photobucket.com/albums/e346/hhteo/P2270267.jpg
http://i42.photobucket.com/albums/e346/hhteo/P2280268.jpg
hhh,
Any other pics other than these? Have any on how you mod your lights - that'll be more interesting for all of us here. Afterall, this the diy section. So, care to share?
sorry,
forget to take the photo for the process of this retrofit project.
For the retrofit,
actualy just need to get a pair of projector lense.
can refer to the link above for the info of the projector lens.
Or can come to me because i can get cheaper than those.
and the fixing of the projector into the head light is depends on the creativity of individual.
the only problem is to take out the hedalight cover by not break it like mine:cry_smile: .
Actually the light output of the projector is not that bright compare to the HID that fix in reflector light.
The projector only spread the light to a large area with even brightness.
Hope this can help.
not bad ah... i think it will be brighter if you use the clear glass head light rite?
can we know the budget to do this diy?
Clear glass definitely will be brighter and nicer look,
but i broke it :cry_smile:.
for the cost,
i got a pair of bosch E46 projector for RM270,(can get it at ~RM200 now)
a pair of mivec headlight for RM100,
a set of OEM 4300K HID kit.(can get it at some metal sheet,bolt nut and silicon glue.
The only thing is the workmanship that cant be charged.
for the cost,
Good job man...really impress
oh... u install HID also ah... no wonder so bright lah... did you try to use the normal halogen bulb? r u serious can get HID in RM500 only? share share lah....hehehe :P
yup,
i fixed the 4350K OEM HID kit into my projector lens.
Because this bosch e46 projector lens is design to fix the D2S HID bulb.
You can refer to the link below:
If you fix the Halogen bulb, i dont think there is any halogen bulb come with D2S base for you.
For the HID kit below RM500 that i mean is the Philips 4350K OEM HID kit lah.
It fix the bosch e46 projector lens perfectly.
Thanks.
hmm...
wht's the different if we add a projector + HID and install a HID ?????
hhh,i have a same question with ggg...
where's your location?
The HID in projector will come out a wide and even beam pattern,
and the light beam have a nice cutoff so that wont blind the incoming vehicles.
you can refer to the pics i attached below:
http://i42.photobucket.com/albums/e3...o/P2270267.jpg
http://i42.photobucket.com/albums/e3...o/P2280268.jpg
and if you just install the OEM 4350K D2S HID kit into the normal reflector headlight, it will causes the glaring if you dont adjust it properly with the glare shield install.
And the light beam will not be that even compare to Projector lens.
Thanks.
My location in Penang.
yup, will show the bracket that hold the projector to the reflector.
that is the process of retrofit the headlight of bro WhiteGSR.
He request to smoked his headlight too.
