how to change rear wheel bearing for wira 1.5??
badguy
any sifu know how to change wheel bearing for wira?
when i take 5 ppl in car
the rear wheel give a very heavy huuuuu huuuu huuuu huuuu sound when driving at about 30KM/H
is it wheel bearing kong??
any sifu can provided step by step instruction for me to DIY change wheel bearing??
thanks alot :lol:
huahh huahh hua..damn easy to change 1....but u need the tools below...
1.jack up u rear wheel.
2.take off u tyre.
3.put down u hand brake.
4.try take out that drum.(use harmer to knock)
5.center n a metal cap..take out also.
6.center hv a 30 nut..open it..u rear bearing will out liao..
very easy 1..no need put grease 1....
yup..u right..i m small mechanic..
The wira rear bearing is paling easy to change 1 liao,but expensive depend with iswara or saga lohhh...bcs 1 set come mahh..with bearing n tyre screw togather..iswara only the bearing only..
i thought the bearing must press to fix it...quite confuse,,what do u mean bearing come one set???...can u put some pic..coz i also got the same problem le?..if easy aas abc then ill try DIY..
come with a set mean is bearing,hub n tyre screw lohh...i donno explain lahh..very big 1 lahh,not only the small small bearing....
Err price around RM100 lohhh....but u need a big screw to open the nut in center hohhh..
good luck
More pics...
Rear:
http://www.stalkerz.com/galant_e33a/Photo_042305_001.jpg
http://www.stalkerz.com/galant_e33a/Photo_042305_002.jpg
http://www.stalkerz.com/galant_e33a/Photo_042305_003.jpg
http://www.stalkerz.com/galant_e33a/Photo_042305_004.jpg
Front: - No need to change whole knuckle, just pump out the old bearing. Cost? RM 50-80 per side.
http://www.stalkerz.com/galant_e33a/Photo_042305_005.jpg
http://www.stalkerz.com/galant_e33a/Photo_042305_006.jpg
Enjoy...
The rear bearings are fully imported from Japan. Cost me RM 250 a piece. Total is RM 500 all together. My old bearings are more than 15 years old... lots of noise when driving slowly.
UPDATE: After changing both front and rear wheel bearings... my FC improved. Used to be 340km @ RM 70... now, 390km @ RM 70. Wow! Worthwhile investment...
wowowo RM 250 ah
i think pump out the bearing is the most difficult part correct?
maybe very hard to force it out from the position!!
any tools to help??
Why dont buy liao n go work shop ask they change to u lehh?? labour around RM20 only lahh i think......15minit can kau tim...
about pump the bearing i think most workshop wont do lohh....
1. he need ask ppl send to machine shop..
2.pump labour about RM20 liao
3.bearing around RM70 1 pair
4.workshop labour lehh??
5.waste time..
They acttualy sale 1 set 1 lohh...
