CUSCO Oil Catch Tank 9mm Fitting *Made in Japan*
RM2xx
(Brand New in Box with 1 Year Warranty)
http://www.boomspeed.com/melissaseow/CuscoOilCatchTank.jpg
PRODUCT DEscriptION: -
One new GENUINE Cusco Oil Catch Tank with 9mm hose for most:
Naturally Aspirated (N/A) cars.
Turbo cars.
It will suit most Nissan, Subaru and Toyota. Please kindly ask if you are unsure with the application for your car.
The dimension of the catch tank is approximately 15cm (height) x 8cm (diameter) in size.
Cusco oil catch tank is used to reduced the oil vapours from going into the air intake charge. The oil vapours contaminate the air intake charge by mixing with the air and fuel that are used to create combustion in the engine.
As a result of this contamination, it reduce burn efficiency, increase detonation risk, and power factor in both naturally aspirated and turbo cars.
Beside reducing the oil vapours going into the intake charge. The oil catch tank enable a turbo cars to increase approximately additional 3psi of boost without the risk of detonation.
It is easy to install, however bracket may need to be modified to suit the application.
INTERESTED PLEASE CALL: 016-3355743
*CLICK HERE FOR MORE ITEMS*
RM2xx
Turbo cars.
