Redzoneconnection oil catch tank
dre42
7,000 RPM
REDZONECONNECTION
Keep the oil mist from your intake!!!!
Oil Catch Tanks collect the oil, moisture and blow-by gas that comes from the top part of your engine.this causes carbon and sludge build-up in the intake system and engine.the oil vaper and blow-by gas is normally recycled into your intake again to lower emissons. this lowers the power that your car can produce.this catch tank is then used to collect the vapers ,build up and keep them even under the hardest driving conditionsit will give you more power due to no oil vaper getting into the intake. An Oil Catch tank is also an excellent engine dress up item..
Universal fit to most cars,compact design,come with the oil level indicator on the side
come with everything you need for install (including Mounting bracket)
OCT007 - OIL CATCH TANK - OUT OF STOCK
OCT004 - OIL CATCH TANK
OCT006 - OIL CATCH TANK
CLEAR STOCK
[email protected]
thank you..have a good day
Call 0123971336/0122698554
yes ,it comes with hose but call/txt 0122698554 or 012-3971336 just to confirm..cheers bro
CALL 012-2698554(Mervyn) - (PJ/KL AREA)
CALL 012-3971336(Ayn) - (AMPANG/KL AREA)
bumping interested? call this guys
