Keep the oil mist from your intake!!!!
Oil Catch Tanks collect the oil, moisture and blow-by gas that comes from the top part of your engine.this causes carbon and sludge build-up in the intake system and engine.the oil vaper and blow-by gas is normally recycled into your intake again to lower emissons. this lowers the power that your car can produce.this catch tank is then used to collect the vapers ,build up and keep them even under the hardest driving conditionsit will give you more power due to no oil vaper getting into the intake. An Oil Catch tank is also an excellent engine dress up item..
Universal fit to most cars,compact design,come with the oil level indicator on the side
come with everything you need for install (including Mounting bracket)
OCT007 - OIL CATCH TANK -RM190(firm)
OCT004 - OIL CATCH TANK -RM190(firm)
OCT006 - OIL CATCH TANK -RM190(firm)
Please feel free to view http://www.redzoneconnection.com for other products
[email protected]
thank you..have a good day
CALL 012-2698554
[email protected]
CALL 012-2698554
