What is the best tire for your Conti?
feezdya
1,500 RPM
Dear conti owner,
Mind to share your tire experienced? What tires on your wheel now...
My MK5 – 19/35/225 Front TOYO and rear Yokohama
Q7 - Europe tires (will update later)
The reason I’m asking this is because I had bad experienced with Yokohama. My front tires year manuf 2010 cracked at the outside side wall and now replaced them with Toyo. Now my rear tire (right) encounter the same problem. When i checked with the tire shop, they said because of my rim is bigger (19") and not enuff air pressure. Its ridiculous!!. My dad's merc also encounter same problem with me (18")..same tires and cracked at inside side wall (all tires). Lucky i checked his tires. Now replace them with Michelin pilot 3.
So any recommended tire guys? I’m looking 19" tires later.:adore:
Feezday , the less air pressure will cause your tyre cracked , and your size are 35 series . TRy the michelin pilot sport . or u can try the run flat tyre .
dear kenneth,
me regularly checked my tires..maybe not my luck la..btw its happen to my fren skyline too..
I also had the bad experience with yoko tyres.....was using ADrive R1 235/40 ZR18....after travelling 15000 km in less than 2 years they cracked on the inner sidewall...those tyres were bought brand new and costed me rm480 each...I am a very fussy person when it comes to tyres, brake and suspension!, and I fucked Yoko eversince!
BTW, Conti CSC2 was the best i have used on my beemer
