New Tires : Front or Rear
ericmaxman
Senior Newbie
Age old argument. Some argue that new tires go behind, reasoning is because of (some) cars' weight is biased to the rear, while others say that since (some) cars are RWD, so new tires go behind.
Personally la, I change my fronts, then run them in for 2-3 months, then get another set to throw the front to the rear. My reasoning? My saga's rear end is light. If I were to put worn tires behind, I'll definitely slide in the wet. Already kena TWICE. So, that 2-3 month can be considered as a break in period to get the tires all nicely "worn" in, so that it'll provide enough grip for my rear end.
On a side note, with my current set of rims, I cant rotate my front to back (this is highly recommended to keep the wear even) since the potholes in KL has been abusing my rims quite badly, and throwing the bad rims up front means it'll upset my tires' balancing.
Now that my front tires are already almost the TWI, it'll soon be time for me to hunt for a new set of tires. :driver:
I wanna hear what your opinions too :biggrin:
many car enthusiasts uses different jj rims for front & back.
but if all round the same jj I will do the same as u.
for me ill throw newer grippier tires at the front, be it my FR or FF (which happens to be an iswara/saga like urs)
for the FF, the front tires do the accelerating, braking (mostly) and cornering, quite the heavy task, and i prefer oversteer than understeer, as the former is easier to recover from (for me, at least)
for the FR, ill still prefer oversteer (although recovery is a more delicate affair than the FF)
with understeer ur intended path of travel (line) will change while with oversteer it is still manageable with the front wheels still on track
Saga blm, forgot to mention that
But personally I prefer neutral to slight understeer, and I've had some bad experience with the tail swinging out....
Send from my ME173X using Tapatalk
Some reading material...
http://www.michelin.com.my/Learn-share/Safety-tips/
Tip No: 6
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=52
Some visuals...
Install Two New Tires on the Rear Axle - YouTube
Personally I follow the above and put new tyres in the rear.
Another reason is putting the older tyre in front I can finish them off faster. Keeping them in the rear they will just go old and harden...
Tip No: 6
Agreed, which resulted in my front tires wearing much faster than my rears.
So in the end, a new set of rims would definitely allow me to do some tire rotation (dont they rotate when the car moves? :thefinger::thefinger: )
You are using all same size tyres, right?
Well, My NA Hyundai have same issues like you. 2 dented rims and 2 good rims, so good ones in front, bad ones in the rear.
When changing tyres, I fit new ones to bad rims then to the rear, then pay a bit more to mount the older tyres to good rims then fit to the front.....:biggrin:
Hmm.. I usually replace all 4.
My parents change 2 at a time so they put the new in the rear. Kinda like that youtube show, wanna avoid loss of rear traction. Can be quite scary mid-corner, experienced before. Can't even countersteer.
https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-xpf1/t1.0-9/10006190_701482673240844_45473082367864004_n.jpg
