Portable Instant Tire Inflator OEM
kazami
Item: Instant Tire Inflator
-This device is designed for you to use it whenever your car tires is under-inflated.
-Instant Tire Inflator: Use 12 volts DC only.
-Designed to inflate car tires, bike tires, ATV tires, sports equipment, air mattresses, beach toy and other inflatable.
-Original equipment from Toyota but it do not come with Toyota labeling. Manufacture have removed it. (mine without Toyota name printed but picture uploaded for reference)
-Safety valve will release the air from the side of the compressor to prevent over-inflation if it is left unattended
-A lot of luxury car makers provide this equipment into the vehicle. Such as Toyota, Lexus, Nissan, ETC.
Advantages
-No more sweat when replacing under-inflated tire or puncture tire.
-It is fast to inflate a tire while replacing a tire takes more than 15mins and get your hands dirty.
-Can pump your car tires at home without queuing in petrol station.
-Easy to use especially for ladies who do not know how to change a tire.
-Safety precaution as we do not know when our car tire will puncture.
Technical Specifications
-Max pressure: 7 Bar/ 100PSI
-Voltage : 12V DC from car lighter socket
-AMP : 15A max
-Performance : 0 to 43 PSI/3 Bar in less than 8mins
-Operating Temperature: -30°C to 70°C
-Weight : 1.6 Kg
-Size : 65mm(H) X 160mm(W) X 155mm(L)
Package includes
-A black nylon casing will come together with Instant Tire Inflator Air Compressor .
-3 types of nozzle will be given ( pin for mattress, bicycle and sports ball).
-AC plug 12Volt is attached together with the device.
-Valve screw/ Air hose with nylon wrapped.
-Pressure Gauge
-Deflate Button
-On / Off Switch
-Can be store under car seats or rear boots.
Price: RM140 each
Warranty 6months
COD Klang. Other place depend. If too far, need to add abit more for my petrol expense.
Contact PM or email me
