Stock ecu + safc + s-itc = result ?
flamefox850
ok 1st of all we know that when we use fuel piggyback such as safc and fools the ecu with false signal, automatically ignition map will be screwed
now i want to know, can we 'fix' that screwed ignition map using s-itc ? means a combination of stock ecu + safc + s-itc
[SIZE=-1]musey, SITC allows altering the timing through the rev range, aka stabilising engine idle also..[/SIZE]
the question is, why do you wan one? your engine idle erratic aka gilo already ka?
i do not know the technicality of it... but a good tuner can squeeze a healthy 20++bhp out of this SAFC + SITC setup... i've been there and done that personally... and a fren of mine with a toyota 1.6 supercharger engine (4aGZE) .. managed to squeeze 19bhp from dis setup... but i think it's more cost effective to settle for emanage rite? back then there was no emanage.. so we went for this kinda setup
can squi....zzzzz 8hp more if u change bigger injector or extra injector controller...
cater with AFC&ITC...
but costly...
another choice is stand alone ECU..... same cost but more flexible on tuning.... less wiring and work time...
