FCD Help
polyxtroy
Dudes,
Any 1 can help me answer these questions ah?
Just installed a HKS FCD. 2 things I need 2 know.
1. What does the numbers on the FCD's dial denotes(Means)
2. I am currently using an SAFC2. I notice that the Map sensor wire to the ECU is already intercepted by the SAFC (But I still experience fuel cut) so I spliced & connect the wire before the it reaches the SAFC. Something like
Map sensor-----FCD-----SAFC------ECU.
Is that correct?
hey dude, fcd doesn't work well with Safc. Better if u go and buy Ketit's ECU and that solve all your problem with the FCD thing. U r interfering with one pressure signal using 2 electronic gadgets la.
I've tried modding a ECU to throw away the cuts before. But didn't work. So not too keen yet. Will try Ketit as a last resort.
