Altezza Topic: SAFC Cannot be used on Altezza?
hansc
fellow altezza owners and enthusiasts....
been reading from the Internet.....and got to know that SAFC is not recommended to be used on Altezza..... is it true? seesm to me that the ECU will automatically retune itself back after a short period of time, resulting in the adjustments in the SAFC useless......
anyone to shed some light?
not sure bout this, but i think martin used safc on his altezza until it got stolen =(. neway, hansc youre from k2oc right? now drive altezza is it?
hi techdroid....... been reading it from the lexusownersclub in uk....
yeah...i am from k2oc.....do i know u by any chances? hahaha...... nah.....not driving any altezza now.......just some preliminary data collection before i decide to sign on the dotted lines for one.........hahahha.......
yes, safc or safc2 do not work on modern toyota with vvt/vvti/vvtl-i engine. thing is that the ecu will pick up signals from the lambda/o2 sensor at the header to determind the optimum fuel mixture.
so, whatever tuning you do on piggy back, it will retune itself back to what it is suppose to be. Unless ofcourse you unplug the o2 sensor's cable, then you can use safc, but then your ecu will run open loop all the time, and if your safc tuning is not perfect, your fuel consumption will be insane, like mine now, its doing 30% less millage than it is suppose to do, and exhaust gas smell like unburn petrol.
i'm not so sure.....
but i'm using the SAFC2 seems like fuctioning quite abit cause i'm tune it on my friend work shop at ipoh. after install and tune it... so far is more smoother on accellation and more power response on rev.
than terrible thing happens on my car....
being windows broke then SAFC2 and RSM has been stole
then my altezza seems like back to stock performamce.but one things for sure
with my SAFC2 and RSM my altezza 0-100kmph is on maximum 6.55 - 7 sec
but without those stuff i try is 8-9 sec
brian try my car once time. he also knew it.
i understand what you say. If altezza's ecu runs the same as 20v 4age's ecu (in term of open loop and close loop operation), then there will be difference if you use an safc.
I dunno for sure, since i'm no sifu. But theorically it sounded like this:
When operating in close loop, the ecu will check the o2 contain in exhaust gas, then it tune itself, thus making safc useless.
then there is the open loop operation in the ecu, which most sifu say if you run without o2 sensor, then safc can be use. So i'm assuming that if o2 sensor not used = ecu running open loop all the time, and then the ecu will run open loop anyway if you full throttle your car. which leads me to belive that one can really see changes in performance when you are heavy on the throttle, not when you drive around town slowly...
very informative indeed......
bro martin,
that is wat i got to know.......altezza ECUs retune back itself after some duration.... from the article, it does mention that the ECU is taking consideration of worn-out sensors and it automatically readjust/retune back itself to cover the problem.......
This is what i call A/F compensation which modern cars are using to meet
worldwide emission standards & as well as fuel saving.
As for the F con SZ, correct me if i'm wrong, it is just manipulating the OEM ECU to believe what it wants it to believe, so then the OEM ECU will compensate the A/F in accordance to the F con SZ setting using OEM O2 sensor. My MR-S is running fine with F con SZ with 40litres of fuel for 500 plus KM.
bottom line is, SAFC or equivalent can never be able compare to any piggyback ECU or standalone and current OEM ECU techonologies
Stepwyew, u wait for william. must be the setting. dun worry about it. or u buy BRACH BOY's PFC. it comes with a wire harness for Automatic altezza.
PLS dun BANG me.
PLS dun BANG me.
Hahahahahahahahahahahaha
just have to wait till this month for the japanese tuner to come in and hack the F con SZ and hope he got the key to access to it . by the way , my altezza just install the throttle body controller by your good friend
porosaki said:
canggih arr? nice arr? got any difference or not?????? :D hahahahahaha must be damnnnnn SHIOK!
Canggih :) Nice:) Got Different :) Yes damnnnnn bloody SHIOK
Hahahahahahahahahahahahaha......lol
Hi stepwyew,
kind enuf to share : wats the throttle body controller?
wat does it do?
coz i drive auto altezza too
thanks in advance
this is what it does.
OEM system when u floor your throttle, the throttle body will be delay for a few miliseconds. with that controller it eliminates that delay and thus u have response.
Hi Ahlian,
Its make your car more responsive when you accellerate and also gear change respond much faster ....... for more info you can call william from trial tuning . his no is 012-2139861
Cheers
stepwyew said:
Hi Ahlian,
Cheers
thanks very much to porosaki & stepwyew once again
u guys really been helpfull to me
i definitely would be much interested in the throttle body controller
...just wondering how much it would costs???
the last 2 weekends, i did not manage to go look for william at trial
bz ching ming and also got some family celebrations
i must go there by this month, april...
its a must......
:regular_smile:
thanks again guys
SAFCII -I install it in my car together with major service like timing belt ,sparkplug, water pump and bla bla bla all changed in one time...then later jerking happen but not too serious...until now haven't got the time to get it fix. So mean don't know whether the jerk comes from the SAFC or other things. In fact i suspected it cause by the mechanic itchy hands coz he took off the pulley during he servicing the car,so may be he never get the pulley angle adjusted properly..
aLIAN, Seriously Poro n Stepyew are nice men...especially this Stepyew ...he's good for everything.
Hello test,
Must Hormat Porosaki Also Others junior And Senior Member Also ,Ppl Like jahak, Brian ,martinchen .......etc,etc,etc.......Bla bla bal bla ......................hehehehehehehehe
hahaa, teng kiu to all for being nice n helpful
