I am driving 1G-FE Altezza.
Recently I had problem starting up the engine.(twice)
first, about a month ago.crank normally but did not start.( no problem with battery or fuse:confirmed by 3 mechanics i took to my house ).so i gave up, and i called the tow truck..but when the the guy came to tow my truck..he tried to start and the engine start normally in first try..crank once and start..).this guy said might be the fuel line fill with air or the filter in fuel pump causing the problem..I just agreed along with this idea...untill last week...:hmmmm:
It happened again...crank normally but not start..as if theres no fuel pumped into the engine....this time..i tried pumping the fuel pedal thousand times..as suggested by the tow truck guy...but didnt work...for days i tried the same thing...untill yesterday...i crank..and it start...:hmmmm:
So now..what the hell is going on..:hmmmm::hmmmm::hmmmm:..anyone ever encountered the same problem?.. is there any problem with the fuel pump.? or fuel line? any advice...
anyway i will bring the car to workshop this weekend to let the mechanic check it out..
any info beforehand would be very much appreciated...
i have owned this car for 8 years..this is the first time this car ever gave me a problem...for 8 years..smooth sailing.
..normal service..normal maintenance...no problem whatsoever...will try to keep as long as i live...i hope...( my wife ask me for to trade for a new car...hehehe )...
..i thought to send the car this weekend...
