starting the car
TRDtezza
tezza owners.
I'm just wondering , how long does everyone takes to start their cars ? 1secs or up to 4 secs like mine ? I'm used to my other cars which just needs one spin of the crank... My tezza seems to need atleast 4 cranks before it starts..(i hope i put it in a understandable way) . I'm new to my car...Its normal for a rs200 to start like this ?
mine so far (*touch wood also) starts with 1 crank.
check battery, check also if MAF sensor dirty.
Normally we will only need 1 crank to start the car. No matter if it is in the morning or afternoon. I would suggest that you have the MAF sensor and the Throttle body clean before you try other things.
In the case of a weak battery, it would either start or not turn over at all. That is what I have experience before.
Other possible cause could be the fuel pump or the fuel line.....
Hope this helps.
Shouldn't take up to 4 secs. It's like other bros said, do the below in order:
1) Check battery
2) Clean MAF/Throttle Body
If not, have to do the below already (workshop maybe?)
3) Starter
4) Fuel pump/line
want to ask, what solvent/cleaner to use for cleaning throttle body ?
i hv a can of contact cleaner which i use to clean MAF sensor, am thinking is it ok to use the same to clean throttle body ?
Are u sure you want to spend yr time dismantling and fixing back the throttle body, mike? Lots of work and make sure u don't damaged the TB..coz it will coz you ard 3K to replace with a new unit...
U can actually go buy a can of Motul Part cleaner..but dont use CRC Contact cleaner on yr throttle body bro...
alright, thanks for the advice.
sifus...
the contact cleaner you are mentioning about is it the same as the some that uses to clean the cd and dvds ?
sifus...
there are diff type/grade of contact cleaner.. but make sure u use those that
stated "Safe on plastics".... i tried to find CRC MAF Cleaner, but maybe i didn't
expand my search area.. therefore i got this & it works for me
