IS250 couldnt start!
alfeoturbo
Dear Forumers...
My IS250 couldnt start at all after a day i did not drive the car.
Mechanic check the fuel pump is working fine and the car cranks when ever i press the push start botton but it just couldnt start.
Anyone experience this before?
just go to toyota/lexus center
they have diagnostic set to be able to determine the failure
before you do even tow the car
you need to let them know your car spec
as variant spec will have different electrical system setup thus some of the diagnostic software wont
be able to support and capture the symptoms
and also to avoid losses because of towing the car.....
Your explanation of your problem is very vague. So your car can not start.
When you turn the ignition on , do you hear the fuel pumps come on ? Does the battery have charge ? When you crank, does the starter motor turn over ? Do you have fuel pressure ?
Please do not just say that your car can not start.
anything to do with yr immobilizer?
maybe call yr salesman and he might be able to advice...or refer to the right technician...
my mark x also couldn't start..mech check wth diagnostic tool also no fault..Mech service t throttle body then its OK again
