Need Help..Running on 2 cylinders!!
Sapeqlaa
Dear all..
In dire need of advice and opinion...my car is stuck at the workshop after 2 of its cylinder lost ignition..to be precise..1 and 4..in order to detect what causes this; my mechanic has done this:
i. Checked n changed the ignition n coil
ii. Checked n changed the plug cable
iii. Checked n tested the ECU
iv. Checked and changed the distributor
but the result is still the same...no ignition at 1 and 4 cylinder...last resort for tomorrow is to get the overall wiring checked..
Aside from that...'check engine' light will not go away and my front headlamp will automatically switched on whenever the engine started..
FYI, its a wira with a mivec 1.8 engine..cannot sleep nite la like this :banghead:...darned...sifoos and frens..please help me...TQ.:confused::banghead:
becoz it affected the headlight.. i assume its cause by wiring issue..
but sometime bad head or block might cause that as well.. low compression on the piston..
Problem solved...manage to trace the problem..seems that one of the 'dimmer' in the ecu is loose plus wiring issues..solution is to solder it..n running fine right now...crossing my fingers though...
