loss power like running 3 cylinder
Mat Indera
My evo 4 engine transplant to waja after running 10-15 minutes suddenly loss power, like running with 3 cylinders and engine check light on. Idling rough and low rpm, engine likely to stall and whole body vibrate. Switch off the engine and start again, the engine back to normal. Be able to boost up to 1.2 bar
After driving 10-15 minutes the same problem come again, engine loss power, check light on, idling vibrate and like running with 3 cylinders. Switch off the engine and re-start, it back to normal again. Please sifu help!! what could the problem.
Than I need to drive until the check light ON and struggly drive to the scan workshop. If left Idling, the engine will dead. If I re-start the check light is gone and engine back to normal. Computer Scan will will not detect any problem.
Serious coordination to be made with scan workshop.
not really.i do believe all ecu will keep memory of error code which pops up.
some ecu can self delete the error code from its memory after s spesific time the engine is restart as it treats the error as a one off.
Checked and found that 2 injectors not function. Injector coil no pulse. Spark plug and coil OK. Change with 2nd hand same evo 4 ecu than running ok for the past one week. ECU problem.
Thanks all for advise
