Modifying stock airbox
Originally posted by khguan@Jan 2 2005, 15:25
hey guys.. got something to ask.. if i just wanto try removing de U-shape piping b4 de air filter box. how to do it ah? need to remove de battery 1st?
izzit possible to replace de U-shaped pipe with a flexible hose as CAI leaving de filter box standard? if can wat size of de hose i can fit in?
you need to remove the battery to unscrew the 2 screws for the U-shape piping...
then you can take out the U-shape piping through the mud flap...don't know the exact name...
for me, i didn't take out my tyre...just turn the steering to the left side :P
i didnt take out my battery... just unscrew my batt only.... then turn ur tyre left and un screw the fuse box.... then unscrew the 2 screw and it is out....
depend on how much you want to sell first...
although im very interested to get the item so that i can get rid of the throttle sound, but also haf to see my pocket first...
my location in melaka wor... :P
anyway, better for me to keep it first until my car warranty over... haha
in case something wrong then i can change it back and claimed warranty...:P
sharing some info..... :D ..........
For everyone that swears that a CAI is not worth while on our cars and that the stock airbox can supply enough air needed, I did a test. I have the EVO CAI and I wanted to try out my modfied airbox. I shaved the top of the box, cleared the bottom of it, added a 3.5" expensive hose to the box from the front of the car, and added an ITG. Well guess what, it pounded the EVO into the ground like a fence stake. No more EVO for me. I am only going to show the airmass but the hp is higher as well, by 3 - 5 hp over the EVO from a block 120.
Stock Box w/ stock filter, smoothed inners = 172 g/s
Stock Box w/ stock filter, smoothed inners, ram hose = 177 g/s
EVO CAI = 178 g/s
Stock Box w/ ITG, smoothed inners, ram hose = 184 g/s
Stock Box Top
http://www.silvergti.com/images/airboxStock.jpg
Smoothed Stock Box, used dremel, sand paper, and love
http://www.silvergti.com/images/airboxMod.jpg
Hose with to much space
http://www.silvergti.com/images/airbox.jpg
Hose with filled in edges using insulation tape, the wire was removed so entrance was smoother later.
http://www.silvergti.com/images/airbox2.jpg
Isulation tape from home Depot
http://www.silvergti.com/images/airbox3.jpg
Bottom box with edges removed, water gate cut, and engine intake sealed
http://www.silvergti.com/images/airbox4.jpg
Front mount hose
http://www.silvergti.com/images/airbox5.jpg
http://www.silvergti.com/images/airbox6.jpg
http://www.silvergti.com/images/airbox8.jpg
Originally posted by drexchan@Jan 8 2005, 01:57
Yes!!! I have the same type of hose.. i think can do 2 cars...
Where you guys get those hose arrrr ..... ??? i searching one for my wira ....
got it from my lab.. previously a vent hose for a scientific microwave oven. Machine spoiled and disposed.. so i took the hose. See http://drexchan.fotopic.net/p12053940.html.
Where can i get those hose ;) ... i mean which shop selling this hose ... i ask the hardware shop before and they didn't sell it ... :(
I got one idea, get it from your vacumm cleaner :biggrin:
whatdamn said:
just my opinion,
don't use knn or the hks (mushroom) filter. use the apexi power intake.
ok knn u need to maintain, hks also need maintainence, and it isn't exactly cheap. whereas the apexi one, all u have to do is at every service just blow high pressure air into the filter and it's good to go again! (it cannot come in contact with water or else ur screwed!)
ok, filteration quality, hks is THE WORST! meant for really track cars or if u hardly use ur car as a daily driver. apexi has better filteration quality than the knn one because, apexi is not oil based and does not need the oil to help in trapping the dirt while sucking in air.
bottom line, go for the apexi power intake.
i felt the difference, not only in a nicer growl from my engine but my 0-100km/h time improved by 4.3 seconds! if that isn't good...i don't know what is.
oh and also, don't buy those 6" open pods for ur car cause u MIGHT feel a slight lag...just like turbo haha. cause ur engine is not that capable of sucking in HUGE ammounts of air at a time.
hope this helps. i'd be glad to answer anymore questions on this filter :)
Did u say u got 4.3 seconds off your 0-100km/h time? Wow! What car do u drive by the way?
Guys,
very useful info, anyone has any ideas about improving the stock Gen2 airbox? so far the stock airbox has a trunk that extends all the way to the front, (same like waja) only think is that it still need a decent amount of air volume, so i'm thinking of opening some holes at the back of the airbox, but i'm only affraid that it will suck in hotair, thinking of opening 50cent size holes..any comments?
ethanphoon592 said:
Guys,
u're gonna drill holes in ur airbox ? dun do that weih... :eek:
