For:
Mini Cooper S II Series 175HP
Code: ACCDASP-26
D1 (mm): 85
D2 (mm): 150
L1 (mm): 200
The CDA filtering system is composed of a cylindrical carbon fibre airbox containing a washable filtering element. The choice of this composite material is due to the fact that carbon has low thermal conductivity allowing insulation from the engine heat to the aspirated air. Replacing the original airbox with the CDA, fresh air is channelled directly to the filter, thermally insulated inside the carbon airbox and then conveyed to the engine through an air flow deflector with minimum loss of power
DREGO IMPORTS (001990983-A)
[email protected]
MOB : +60123505832(whatsapp,viber)
OFFICE :0356361481
Code: ACCDASP-26
D1 (mm): 85
D2 (mm): 150
L1 (mm): 200
[email protected]
OFFICE :0356361481
