Info : Mitsubishi Manual Transmission Spec's
vestax
1,500 RPM
Here is some sneek preview of the user manual from mitsubishi motors . So if you need more info on the gearbox specs or details to remove stuff from the gearbox please let me know i`ll post the page's , cause it has lots of pages and from all sorts of models .
http://www.fivio.com/vestax/vr4/transmission/Manual.jpg
http://www.fivio.com/vestax/vr4/transmission/F5M21.jpg
http://www.fivio.com/vestax/vr4/transmission/W5M31.jpg
http://www.fivio.com/vestax/vr4/transmission/W5M31v.jpg
http://www.fivio.com/vestax/vr4/transmission/W5M33.jpg
http://www.fivio.com/vestax/vr4/transmission/F5M22.jpg
http://www.fivio.com/vestax/vr4/transmission/Torquespecs.jpg
http://www.fivio.com/vestax/vr4/transmission/Gearratio.jpg
Originally posted by ezwong2002@Jul 30 2004, 10:11 AM
ves, can i buy vr4 cluth kit for my gsr g/b? I'm not sure about the exact size.
Ez the mirage turbo , gsr , vr4 & evo sharing the same diameter clutch that is 9" , but the problem you can't use the vr4 clutch cause gsr & evo runs on 7 bolts on their flywheel , where else mirage and the vr4 is using 6 bolts . I think to use the clutch disk won't be a problem , but clutch cover have to use back your gsr one , anyway im not too sure about that , maybe other's can verify on that .
Acbc ,
Auto tranny ? hehe i guess its really hard to find info on it unless its from a famous model , best is to go to any mitsubishi dealers or go to hicom and ask for the usermanual . I`ll try to ask for you since 1 of my friend's father is 1 of the board of directors in hicom , so i bet they have most of the mitsubishi gearbox usermanual , cause they build gearbox for proton using the same design from mitsubishi .
from mah experience, i use evo clutch cover n evo plate, all evo on mah GSR gear box...
hope it clarifies... tho many mechs says cannot b done, no extra mod needed, jus plug n play...
cheers
so could i use the ori mmc evos friction disc and use back my gsr clutch cover? how about the flywheel?
thx ^^
[snapback]316691[/snapback]​
Can I have the ratios for VR4 and Perdana Sei (M) ?
Hi there, i need sum help regarding gearboxes. I think i ve just busted my tme's gearbox. Which part i m not sure but this is how i did it.. dialed in 7000revs.. dumped the hks twinplate clutch. There was a bump sound then the car just wudnt move.. Engine is still running as per normal. What i need is actually a diagram or something regarding the gearbox of the evo6 tme. Would really appreciate ur help. Thanks..
Ari
Guy's if you need the manual on those gearbox , email me at [email protected] and i`ll attach it . Make sure you guy's have more then 6mb inbox space . As for the new gearbox i don't have the manual , but i have a manual that teaches how to repair the gearbox in general and there might be slight difference between the newer models but i think it does help in general .
eh...the links dont sem to work anymore...
does the 4g93NA and 4g93t share the same manual gearbox? probably not eh...heheh! do you have the ratios for both? thanks!
mr vestax... y i can't view ur img... huuu...
I've just bought manual transmision for my auto gsr. But I want to knw to, what else do I need tocomplete it beside the clucht and how much does all it cost?
