How do I enable my cut off?
Wira3047
Hi all,
Previously my foreman did a mechanical process where my cut off was removed however my idling was bad.
I want to enable the cut off but I can't seem to find any screw behind the meter or any disconnected wire in the ecu.
I'm using gsr and I need some help...Thanks
My guess is boost...
Check the throttle body area... Ur foreman would hv installed a bypass valve there.
