kena racun dah!![]()
hulkv6tt, i think it's just to slow the 6MT replacement..heheh
my opinion...if budget is tight..just use the A/T until kaput..when the time comes when it kaputs, then u decide, either to replace the A/T with a used A/T or just simply change to M/T (not just change the gearbox, but basically the engine with M/T)
if got budget...then just do like what AE111_SEG did..change to M/T if u cannot tahan the racun![]()
Hey this thread is changing from 5AT problem to 6MT racun
Redsider... you are new here I see. Your friends complaining about ur ratio?... What final drive are u using 4.1 or 4.3 or aftermarket 4.5.? What is ur RPM at 100km/h
---------- Post added at 06:03 PM ---------- 6 hour anti-bump limit - Previous post was at 06:02 PM ----------
Kena racun after I drove you car.....![]()
lets dig more to technical........why dont we fix the root cause of the problem. MAYBE cheaper, less work (maybe too)...
Bro hulkv6tt, install a transmission oil cooler kit if u want the gb last longer . Cheers
mokh, the gb is sourced by kenny of kenagi, if u r looking for one, Cheng (our tezza member) also have one to let go with a mileage of 80k++...
(0123998273) rm1k also...give him a ring.
so many question? mana ada ok lor!!!any mean to help an alterazzarian is a pleasure...![]()
