Engine Cover Spray , Lettering emblem only
jinkl-
What u need
1 . your spray paint
2. masking tape
3. fire source
4. candle
5. hair dryer
Ok first melt candle on ur engine head where needed like this :
http://noelle.enacre.net/Candles/topimage.jpghttp://noelle.enacre.net/Candles/topimage.jpghttp://noelle.enacre.net/Candles/topimage.jpghttp://noelle.enacre.net/Candles/topimage.jpg
http://x4.putfile.com/6/16302343546.jpg
Then scrape it with anything , scrape the candle which touched the wordings
please also use sandpaper to clear the wordings from wax
http://x4.putfile.com/6/16302353048.jpg
Mask the areas
http://x4.putfile.com/6/1630238429.jpg
Ready to spray , spray larr hehe
http://x4.putfile.com/6/16302405644.jpg
After this , let the paint dry , after that
use a hair dryer , melt the wax at the sides all , and use a tooth brush to
completely remove em.
http://x4.putfile.com/6/16302532140.jpg
Final product :
http://x4.putfile.com/6/16302484790.jpg
hehe , if kena anywhere not supposed to , just use some petrol and clean it up
wah... very good idea!!! but ur finishing doenst look "expensive" ler... like not so smooth... izzit because of de remaining wax after u scrapped off??
hair blower enough hot to melt those wax ah?? i think use de hot air gun will be more appropriate.. :)
my car engine cam cover dun have any words.... so i cant do this DIY.. hehehe :p mayb have to find some other parts with words to do.. hehehe :D
anyway... good job!! keep those ideas coming!!
Good idea to use candle wax as masking!! But ur paint looks not really bonded to the surface lar.. cheap spray?? hehehehe
its b'cos of da wax... i think jin neva sand the surface properly... looks like he on scraped it out... surface shud be 'wax free' b4 spraying for better results...
no need to use hi temp spray (limited colors).. normal 1s oso can..
better use metallic/ candy tones... looks more 'gempak' ... cost only rm9...
a big mistake i did guys
the silver colour is high temp
its not the candle on the emblem
u must undercoat first before spraying the CANDY BLUE
CANDY BLUE is like a CLEAR COAT BUT SILVER
it requires undercoating , black or silver , both end up with diffrent kind of finishing
will redo mine soon :) u can see the black sticks cos its undercoat black but not the blue
