DIY : Spray Door Handles
johnsonlam
DIY King
Hi Folks,
Here are some DIY Steps to touchup, spray and fix a CIVIC door handle.
STEP 1 :
SandPaper the Item.
Use Corse to fine sand paper to get the smooth finishing..
http://www.tbspeeders.com/forum/files/dsc03956.jpg
http://www.tbspeeders.com/forum/files/dsc03959.jpg
http://www.tbspeeders.com/forum/files/dsc03957.jpg
Next : Spraying... Use thin layers.. let them dry before adding more layers..
http://www.tbspeeders.com/forum/files/dsc03961.jpg
http://www.tbspeeders.com/forum/files/dsc03962.jpg
Next : BAKING !!!
Yum Yum.. carefull.. not too long.. you might MELT it instead..
http://www.tbspeeders.com/forum/files/dsc03965.jpg
http://www.tbspeeders.com/forum/files/dsc03964.jpg
DING !!!
DONE !!!
http://www.tbspeeders.com/forum/files/dsc03967.jpg
Remember to Drink 100plus.. Ovens are HOT !!
hi johnson, a very impressive DIY indeed
by the way i got a question. did u pre heat the mini-oven first before you put it in or you just put the door handle and heat it up.
Originally posted by alantan@Jan 3 2005, 19:31
one question also..why myust heat the door handle..what is the different?
to make sure the inner layers are properly dried. if not, it will chip before the inside dries.
