Confused with DP0/AL4 atf
KrisMas
Hi guys, need some enlightenment from sifus here.
My ride is with DP0 gb as below
Now, after doing some online search, I was able to obtain both DP0 and AL4 transmission manuals. Also from my online readings, seems like the terms DP0 and AL4 are used interchangeably as though the two are similar. But, after reading (more like browsing through) both manuals, I'm a bit confused as the manual for DP0 recommend to use Elf Renautmatic D3 Syn but for the AL4 it's Esso/Mobil LT 71141.
So, which is actually most suitable for my tranny and, not to mention, to our weather/climate here? Both are selling at around the same price over here so it's now up to which one is most suitable. I dare not go outside these two so, for now, no other ''equivalent" please (unless you have sound and documented TECHNICAL data/experience to back it up).
Another thing, below is how my atf looks like after the fourth drain/fill with Elf Renautmatic D3 Syn over a period of around two months. Am I good or do I need to do a few more rounds or is there something wrong with my gb?
Thanks in advance.
