B8 180 395Bhp
microtech-info
This is some info already build from Rpm2 Racing,to make it big number horsepower from B8 180engine.U can check at http://rpm2racing.fotopages.com for more information.
Engine Spec Sheet
Engine: BP 1.8 Turbo
Bore: 83.5mm
Peak Hp: 395.7whp
Dyno Type: Destec Dyno
Pistons: Wiseco
Rods: Eagle
ARP:ARP Head Stud
Block Mod: Rpm2 Racing
Machine Work: Rpm2 Racing
Camshaft: Toda
Intake Manifold: Custom
Turbo Manifold: Cusrom
Turbo: Turbonetics
Injection: 1000cc Bosch injectors
Fuel Delivery: 2 Bosch 910 Fuel Pump
Engine Management: Microtech LT10s
Boost Control: Turbosmart E-Boost 45psi
Boost:20psi
Spark Plug: NGK Iridium
WasteGate: TIAL
Clucth: Trinity Kevlar 6 Puck
wah.. kaw kaw wei... i want 250 ponies oso so sakit wanan keluar duit.. now this guy pulak is 400 ponies... shitz.. dats da bomb wei...
Torque and Hp
U can see the Torque and Hp Dyno,Just click at
http://rpm2racing.fotopages.com/?entry=589903&back=http://rpm2racing.fotopages.com/?page=0
Manifold
I got the IHI RX6 turbo and can make a new style banana...
Banana just $950 and Turbo is a new $3600.Before u fix it..u must have a EMS to control fuel and Ignition timing
wow... 3.6k... phew... think 100 times b4 buying.. but the header is very attractive.. if i was to juz install the header would it be possible? as i wanna do things one at a time now... learnt from my mistakes... i'm currently running a 180 with a 1.8 gearbox bt everything else is 210 other than the block. the block and internals of the engine is still a 180. sorry for too many questions ya.. coz.. still learning...
microtech-info said:
This is some info already build from Rpm2 Racing,to make it big number horsepower from B8 180engine.U can check at http://rpm2racing.fotopages.com/ for more information.
Engine Spec Sheet
Bore: 83.5mm
Peak Hp: 395.7whp
Pistons: Wiseco
Rods: Eagle
ARP:ARP Head Stud
Camshaft: Toda
Turbo: Turbonetics
Boost:20psi
WasteGate: TIAL
Puiiiiyoooo..... CAM TODA tuuuuu.......
in future... wish to have dis set... huhuhuhuhuhu
