D16 SOHC 170whp
microtech-info
Untill now we never see the D16 sohc non Vtec can make the best HP on the dyno.Now we from RPM2 Racing already finish build the D16 engine and get the max hp on the standart engine.After do some standart modification we get 170whp.Let's to share some info with u.
Engine:D16 Sohc non Vtec(1.6L)
Bore:76mm X 90mm
Peak Hp@rpm:7800@160whp
Dyno Type:Destec
Pistons CR:11.1:1
Cond Rod:OE
Machine Work:Rpm2 Racing
Cylinder Head:Polish only
Valve spring/retainer:Vtec Sohc
Cam:282 regrind cam
Intake Manifold:OE
Injectors:350cc
Fuel Dilevery:Bosch 910 fuel pump
Engine Management:Microtech LT10s
Spark Plug:NGK
Ignition:single FireBall coil.(45,000V)
Cost all modification about RM8500
For more information pls contack
[email protected]
http://rpm2racing.fotopages.com
i heard u just blown the engine? now rebuild it back aa?
remember me last time coming to ur place to install microtech for my fren?
its a mivec turbo.
reliability wise?? sometimes u can gain hp more on dynoed .. but when it comes to normal or advance driving.. the engine arent capable of taking the hourly run..
i believe that car only meant for track... m i rite mtech-info...
but not sure if the engine oso can use for on the road.. mean the engine reliability...
Bore:76mm X 90mm
Dyno Type:Destec
Pistons CR:11.1:1
Cond Rod:OE
Cam:282 regrind cam
Intake Manifold:OE
Injectors:350cc
Spark Plug:NGK
[email protected]
Good job there:regular_smile: well done, but fren,,,,76 x 90 is not 1.6 anymore,,,gotcha :shades_smile: . What piston you are using, frankly what mm ?
I 2nd this... it should be for race only!
with 282cam profile, i thinks its idle at 2000rpm..
Why not swap B series, bcoz they wan compete at 1.6NA category for this coming Sepang drag battle... ermm it would be nice..
u guys preparing the engine for Sepang Drag is it?? What kinda quater-mile times are u targeting with the setup??
yeh..the engine is not blowup..have a problem from radiator cover broken.That day have a mivec turbo when the dyno time.The car only for drag race.This my own car.for coustemer i can give a red line.coz of daily driving.I want to see what can i get from the standart machine.:regular_smile:
Still research bro..not target for darg sepang.hope one day can joint for drag race.I must do everyting complete with tranny..hope can get best time 13.0s my target.
