Item(s): MTX TA1004 4-Channel Amplifier
Package includes: 1 units Amplifier
Price: SOLD!!! SOLD!!! SOLD!!!
Dealing method: COD (Damansara, Bandar Utama, Kelana Jaya, Subang Jaya....)
Location of seller: Damansara
Contact method/details: 012-21 363 07 (Avin)
Item(s) conditions: Absolute MINT Condition...Very Well Taken Care Off....
Picture: As Per Attached
Reason for sale: Upgrading...
This 4-channel amplifier has the most flexible crossover we offer. On both front and rear channels, it's variable from 40Hz to 200Hz and selectable for either stereo high pass or mono low pass. The "Non-Fading Summed Output" jacks provide a line level summed output of the right front/right rear and left front/left rear input signals. This output is typically used to drive an external subwoofer amplifier. The parallel input switch allows a 2-channel signal to drive all four channels (no need for a "Y" connector). This amp even has the MTX Audio Thunder EQ bass boost!
THUNDER 1004 Specifications
• RMS Power measured at 14.4 Volts DC:
125 Watts x 4 into a 4 Ohm load
250 Watts x 4 into a 2 Ohm load
500 Watts x 2 bridged into a 4 Ohm load
• Signal to Noise Ratio: ≥110dB A-Weighted
• Damping Factor: >200
• Frequency Response: 20Hz-20kHz ± 0.25dB
• Maximum Input: 8Vrms
• Thunder EQ: Variable Bass Boost (0-18dB) centered at 40Hz
• Crossover: Variable 40Hz to 200Hz, 12dB/Octave Stereo
High Pass, 24dB/Octave Mono Low Pass, or Full Range
• Dimensions: 17.8" x 9.75" x 2.1" (45.3cm x 24.8cm x 5.3cm)
