Thunder895 5-Channel Amplifier
Its a Used Mtx 5 channel Amplifier with high rating. 75A fuse. U judge ur self wheather is a great amp anot (normally, to see the amp power, see its fuse rating. High mean more power.)
This amplifier is flexible in its design, for a single amplifier/factory integration that makes sense. The crossover is fixed at 85 Hz, defeatable high pass on the front and rear, and low pass on the sub channel. Thunder895 also features Thunder EQ bass boost and EBC port.
Specifications
RMS Power 12.5 VDC
Input
Low Level Input
Crossover(s)
Hi Pass @ 85Hz - Front/Rear, Fixed, Defeatable
Low Pass @ 85Hz - Sub Channel Fixed
Thunder EQ
EBC2 Port
2 Ohm Load
320 w x 1
70 w x 4
4 Ohm Load
160 w x 1
35 w x 4
Bridged 4 Ohm Load
140 w x 2
Dynamic Power 14.4 VDC
2 Ohm Load
490 w x 1
100 w x 4
4 Ohm Load
245 w x 1
50 w x 4
Bridged 4 Ohm Load
200 w x 2
Dimensions (with ISO Feet)
15.6" x 9.75" x 2.1"
39.7cm x 24.8cm x 5.3cm
For more info on this product please visit http://www.mtx.com/caraudio/archive/2004amps/thunder895.cfm
Specifications
RMS Power 12.5 VDC
Input
Low Level Input
Crossover(s)
Thunder EQ
EBC2 Port
2 Ohm Load
320 w x 1
70 w x 4
4 Ohm Load
160 w x 1
35 w x 4
Bridged 4 Ohm Load
140 w x 2
2 Ohm Load
490 w x 1
100 w x 4
4 Ohm Load
245 w x 1
50 w x 4
Bridged 4 Ohm Load
200 w x 2
