How does Fluidampr work?
Why your engine needs a damper
Each time the air/fuel mixture inside a cylinder is ignited, the combustion that occurs creates a torque spike that is applied to the crankshaft through the piston and rod. This torque spike is so severe that it not only turns the crankshaft, it actually twists the crankshaft ahead of its normal rotation and then the crankshaft rebounds. This twisting action is known as torsional vibration. When these torque spikes and forces get into phase with the natural frequency, critical torsional harmonic vibrations occur and can be seriously destructive to the bearings and the crankshaft. Dampers are designed to control those destructive vibrations.
http://i107.photobucket.com/albums/m306/babymelon_lst/dragstar/fluidampr.jpg
Rubber VS Silicone Fluid
Critical harmonic vibrations occur numerous times in a engine’s operating range. Stock rubber and elastomer-type dampers are frequency sensitive “tuned absorbers”, and work at only one critical frequency. In the case of a stock rubber damper, it is tuned for a factory engine’s critical harmonic vibrations. If you change the mass of pistons, rods, or the crankshaft, you change the natural frequency of the crankshaft assembly; therefore, the stock damper is no longer tuned to the new frequency of vibration, and you may be headed for early failure of expensive engine components. Dampers also create heat while they work, and rubber is a poor dissipator of heat. This heat and the exposure to the elements deteriorates rubber, causing it to crack and change durometer, which then leads to inertia ring slippage, damper failure, uncontrolled torsional vibration, and costly engine parts breakage.
http://i107.photobucket.com/albums/m306/babymelon_lst/dragstar/fluidampr1.jpg
Availabe model for:
Mitsubishi
Evolution 1-3
Evolution 4-9
Subaru
EJ20
Honda
B-series
K-series
Toyota
Supra 2Jz
Nissan
Skyline R32
Sykline R33
Skyline R34
Fairlady VQ35
*Fluidampr® Harmonic Dampers Made in U.S.A.
Price:
Call For Best PRice
Dealing method:
COD
Location of seller:
DragStar Performance Centre Sdn. Bhd
No. C-1, Jalan PJU 1/45,
Aman Suria Damansara,
47301, Petaling Jaya
Selangor Darul Ehsan.
Contact method/details:
Tel: 03-7880 4804
Fax: 03-7805 2604
Email: [email protected]
Website: http://www.dragstar.com.my
Operation hours:
Saturday - Wednesday
11am - 8pm
Age of item:
NEW
Availabe model for:
Mitsubishi
Evolution 1-3
Evolution 4-9
Subaru
EJ20
Honda
B-series
K-series
Toyota
Supra 2Jz
Nissan
Skyline R32
Sykline R33
Skyline R34
Fairlady VQ35
Price:
Call For Best PRice
Dealing method:
COD
Location of seller:
Tel: 03-7880 4804
Fax: 03-7805 2604
Operation hours:
11am - 8pm
Age of item:
NEW
