[WTS] APS Top Mount Dual Entry Intercooler
DragStar Performance
With Top Mount Intercoolers, Bigger is Better
So here's the BEST!
As boost pressure is increased, the temperature of the inlet air increases and robs power from the engine.Substantially revised for 2003, the APS dual entry top mount intercooler with twin induction to better spread the cooling effect on the incoming charge is designed for maximum street performance on any MY01 onwards WRX or STI. With the significantly lower pressure drop (less than 0.02 Bar / 0.3 psi at 240 kW / 320 hp across the intercooler and 1.6 psi total pressure drop including the throttle body), it's a perfect partner for a high output roller bearing turbocharger.
For optimum performance, the intercooler core itself is internally finned with large internal charge air channels. This results in huge cooling capacity with very high contact area for heat transfer and the highest volumetric air flowrate. Just as importantly, the APS cast alloy end tanks ensure even charge air distribution through the intercooler core without "hot spots" commonly found in aftermarket intercoolers. That along with a huge 11,075 cm3 (677 in3) of intercooler core volume compared to the standard intercooler's 4,305 cm3 ensures the maximum possible intercooling performance.
At nearly 2.6 times the volume of the standard intercooler, the APS top mount intercooler is absolutely the largest top mount intercooler that is possible to practically install in the late model WRX or STI - with core dimensions of 51 cm x 19 cm x 11.43 cm (20.07" x 7.5" x 4.5").
http://i107.photobucket.com/albums/m306/babymelon_lst/dragstar/tmic.jpg
http://i107.photobucket.com/albums/m306/babymelon_lst/dragstar/bov_mount.jpg
Blow off valve mount cast into the APS TMIC for direct bolt on fitment of factory style flanged blow off valves.
http://i107.photobucket.com/albums/m306/babymelon_lst/dragstar/fins.jpg
http://i107.photobucket.com/albums/m306/babymelon_lst/dragstar/stock_sti_fins.jpg
*Please note that the APS TMIC includes the APS one piece compressor discharge duct. This high flow casting has superior flow to the two piece STI component and vastly superior durability to the standard plastic WRX duct.
The APS Compressor Discharge Duct guarantees reliable air supply and is designed to withstand and tested to extreme boost and temperature conditions.
Item(s):
Package includes:
1.INTERCOOLER ASSEMBLY
2.GASKET - Intercooler Entry Duct
3.GASKET - Blow-off Valve
4.BRACKET - Intercooler Mounting
Price:
Please Call For Best Price
Dealing method:
COD
Location of seller:
DragStar Performance Centre Sdn. Bhd
No. C-1, Jalan PJU 1/45,
Aman Suria Damansara,
47301, Petaling Jaya
Selangor Darul Ehsan.
Contact method/details:
Tel: 03-7880 4804
Fax: 03-7805 2604
Email: [email protected]
Website: www.dragstar.com.my
Operation hours:
Saturday - Wednesday
11am - 8pm
Age of item:
NEW
DragStar Performance Centre will be close fro 30th Sept till 5th Oct 2008
Because we are celebrating Hari Raya.
Selamat Hari Raya for DragStar Performance Centre
Location of seller:
DragStar Performance Centre Sed. Bhd
Tel: 03-7880 4804
Fax: 03-7805 2604
Website: www.edragstar.com
come & visit us at
Tel: 03-7880 4804
Fax: 03-7805 2604
Location of seller:
Tel: 03-7880 4804
Fax: 03-7805 2604
Operation hours:
11am - 8pm
please feel free to drop by
Location of seller:
Tel: 03-7880 4804
Fax: 03-7805 2604
Operation hours:
11am - 8pm
Location of seller:
Tel: 03-7880 4804
Fax: 03-7805 2604
Operation hours:
11am - 8pm
All email have been reply so do the PM.
Please check your mail & pm
Location of seller:
Tel: 03-7880 4804
Fax: 03-7805 2604
Operation hours:
11am - 8pm
Location of seller:
Tel: 03-7880 4804
Fax: 03-7805 2604
Operation hours:
11am - 8pm
Location of seller:
Tel: 03-7880 4804
Fax: 03-7805 2604
Operation hours:
11am - 8pm
