what is ur opinion??
amae92
quote from another forum:
i need someone who have experience with LSD to comment this.. is it true?
"After 'testing' for so long... LSD is kind of fun. But when it rains and
highway is semi flooded... driving LSD is a nightmare. Even when going at
80KPH, the steering will try to throw left and right. Hand also penat
trying to control the car.
But when it's dry, you can just slide into any corner at full throttle
with good traction! And when launching, the wheelspin is so minimum you
can feel the car really pickup faster."
"But one thing bad.... the lsd gearbox make a lot of kluk kluk sound when
taking slow corner or parking the car..."
Agree with u. i m using full lock lsd and when it is raining or the road is in wet cond, try to drive slow coz when cornering n with full throttle, ur car will understeer. it is a bit dangerous. Dry road is superb. the Kluk Kluk thingy is normal lah bro...
so, how about using the 1 way or 1.5 way LSD....
i dun think the situation will be the same...or will it..?
yea..that question come in my mind oso.. how?how?
another Q..what type of LSD in 4age 16v from levin ae92?? izit 2 way or 1way or 1.5 way...coz my newly installed come with LSD but dunno what type itis..
u can test and see for ur self....
by jacking up both the front tyres of ur car....
and try spinning the wheels while it's in the air...
yaa..oredi done that.. spin 1 tyre and the other side spinning oso.. but how to differentiate its type?between 1, 1.5, and 2 way?
if u like to differentiate the type, u have to bare up ur gb...or u can do that by peeping inside the driveshaft hole. See through normally 1.5 way.
u spin the left side tyre anti clockwise....if both spin, i think full lock LSD...
if not, u try to spin the left tyre clockwise....if both spin it's 1 or 1.5 way....
the kluk! kluk! sound is believe it's your drive shaft not LSD...
or your LSD is a clutch type which noisy ...heee
not all LSD have the same characteristic...
some react to silicone fluid heats, different speed, different torque, clutch type, some uses parallel-asix gearing, which relies on internal friction to transfer the torque and more...sooo...with these type of LSD...how you going to detact it with your bare eyes ? some can some can't... unless you whack the car and give it a test... even some of these LSD operates normally during normal driving or conventional open design...
Woit... amae92, no wonder didn't see u during last TT in Ipoh la.. so you finally swapped out your engine? LSD wor... must be power!
sorry ipoh guys.. i suppose to tell u earlier. but not about my car.. actually i move to kl. rite now working at HP tower damansara height. and i stay at gombak. really miss ipoh lor..about my se, nothing spesel.. just normal swap. no modd2 done (yet) :p so.. not so power like u all laa...hehe
Orr.... no wonder lar. :biggrin:
hehe if can ipho member can bring me go eat the ipoh chicken rice ah...wat gar coi kai ah....
not now lah....when september..my car can't drive now under workshop ..
Back to the topic.....but a bit lari skit.....how much cost if i want to open all my gearbox....c56..mainly to overhaulin....any guys here done it?????? just the labour charge how much?????
Have you try changing into good quality LSD gera oil. Last time i change the chicken brand have this type of sound. Then change to Redline or Motul then ok.
nnik should be around 300 bucks done all!
mine also opened up b4 for checking checking....
