hi ya guys. im having a problem with my engine. wonder if any of you guys out here can help giving some insights on the problem.
okay, my engine is a b16a engine including all of the thingy inside it except for the piston, which is from b16b. every time when i go back to my hometown, after driving on 110kmj for like 2 hrs, the engine won't start. it wont even crank. so usually i turn the ignition key on and let it for like 30mins,only after that (*if lucky*) can start, thinking that maybe the problem in with the cooling part. so send the car to a workshop, but that fella told me my block has a small crack. then i went to another shop and the mechanic told me that maybe something is wrong with my starter. he even checked the block to see whether the so call crack exists or not.
final outcome= no crack, pressure ok & circuit in distributor changed.
it was okay for a few weeks, but recently the engine's acting up again. haiya. what could be the problem:hmmmm:
? any ideas guys?
? any ideas guys?
