wastegate for evo 2
hey there....r u gonna boost higher than stock?u've got everything on the list?
safc,fuel regulator,piping intercooler,metal gasket...fuel pump that can support higher boost requirement...
erm why dont u get tial 38mm i think....the one with purple colour but be sure to get the spring/diagphram 1 bar(try pm jinkl or any other sifu's,miton and other master :D).....the spring can hold higher boost...u can try n search in this thread for more info..just trying to help......:D
i plannin to boost higher than stock. plannin to get those stuff. have some already. just donno which size to get for the wastegate.
actually there is a problem getting a 1bar spring
if u buy a 0.7bar spring u can use a boost controller and boost higher
but if u get a 1bar one , ur min boost is gonne be 1bar :)
there comes another problem , if u buy a 0.7bar spring and want to boost 1bar , u better get a good boost controller , either way got pro and cons , but tial 38mm is more than enough
U can modified the stock spring - provided with cheap boost controller and good BOV; cheap solution. Otherwise safer to use wastegate and boost controller but $$$$. :)
