Upgrade turbo.
wannaz
Hi semua,,
Need some help..
1. Can anyone tell me how much it cost to upgrade turbo TD05H(evo2) to TD05H/20g.?? and where ..???(klang valley)
2. Evo2 turbo..single fin or twin fin..???
regards...wan
Hi semua,,
Need some help..
regards...wan
could cost u around 1.5k to make it to a 20g + td06 turbine wheel
evo 2 turbo is a twin fin
yes and no..
both turbine volute is 7cm2, BUT, evo-3 is lighter due to some weight saving methods.
some ppl would use a Garrett comp wheel with similar dimensions to a 20G (original Mitsubishi)... so for 1k... you'd only get a Garrett wheel.. if you're lucky you might find a second hand 20G wheel outside...
thks again sum,,hope i will fine one...
td05 20g was said to be not so nice in dsmtuners forum
maybe the 05h turbine wheel is a restriction & more back pressure
20g + td06sl turbine wheel seem to be a nice combo
but then again, original MHI compressor wheel + turbine wheel doesnt come cheap :)
gurantee to make u faint after hearing the price hehehe
the stock TD05 turbine wheel needs to be "clipped" or "cut back" to allow it to flow better once mated with the 20G or a Garrett wheel..or else..it'll start choking out.
why DSM fella's prefer the TD06 turbine wheel..mainly due to size and if you go for the Td06L2 (newer design) , less number of blades and spread out further, hence you don't need to cutback these turbine wheels.
Bump: the stock TD05 turbine wheel needs to be "clipped" or "cut back" to allow it to flow better once mated with the 20G or a Garrett wheel..or else..it'll start choking out.
true :)
td06sl fits the vr4/evo1-3 turbine housing
the td06h doesnt fit the evo3 turbine housing , housing too thin no meat to port hehehehe
td06sl comes pre clipped
