AR60or TD05H...
WiiR4
Hi! just want to ask an opinion, which is better Garret AR60 or TD05H with 20g Fins for my 63T engine, some said goes with TD05H and they're others that said AR60 is much more power then TD05H, is AR60 is slightly bigger then TD05H or same? need some opinion & guide here plz :adore:
What is 63T engine? Could be more specific or not... VR4, EVO, ... but isn't it already a TD05? GSR uses TD04...
My 63T is VR4 220 & in the engine bay is Evo2 TD05H (Twinblade) & got 1 AR60 M24 (also Twin Blade) turbine ball bearing, so which is more respond or better? :adore: plz any sifoo...
if your internal part not upgrade just use TD05 twin 16/20.
erm nwdays , 4g63 with internal parts ppl whacking till 4xxhp :D
my advise is upgrade to a evo3 stock turbo or
go upgrade ur current td05 to a 20g + upgraded turbine wheel , should be in the 1.5k range
