Turbo Actuator
ondgennis
hi all,
anyone know what is the symptom when the turbo actuator is spoil.
what happen to my car now (B8 180 - vj20), the boost was not able to hold. it only reach max 0.5bar and the boost slowly drop to 0 bar even i didnt let go the throttle. I have hks evc4 to control the boost but the problem still occurs. i try swap the evc4 to tulang ikan but same problem occurs.
bov also tighten and leaking is not happen on the bov. most of the vacuum hose had been replace. idle rpm also nice and not up n down.
pls help...
There are a few damages that can occur to the actuator.
Spring weak.
Spring jam.
Diaphragm bocor
Symptom
inconsistent boost
Cheap way, add washer to increase the boost again. But there is a limit of boost and it's only for temporary solution.
Wastegate lor... Solve the problem. Get better ones... Stable and reliable. But dun get chicken brand. Price justify the quality.
can evo4 actuator use to replace my current one?
heard that the e4 actuator only open at 1 bar (correct me if wrong). will the ebc help to open the it early it let say we set it at 0.8bar.
What do you mean by open..?
U meant open and leak the remaining pressure to the exhaust..?
I thought stock evo's boost is 0.9bar....
I guess U are talking about electronic boost controller (ebc). Well to increase or decrease the boost pressure, there are a few method. It's all about the pushing the actuator with the compressed air in the system.
Like the TD04, the length of the rod that connects to the actuator can be adjusted. So, actually quite easy to adjust.
The boost can also control by giving false pressure from the intercooler system to the actuator by leaking out the air during the pressure transition from the intercooler system to the actuator.
By the way, why would u want to reduce the boost pressure..?
Better buy an Evo8 or 9 actuator. Some of my friends' Evo 6 and 7 got problems with their actuators already, so I can't imagine how good an Evo4 actuator will be and how long it will last. Like Speed2horizon said, go wastegate.
Ya man.... go for wastegate... Ultimate solution. If got budget, go for synapse... Kekeke..
speed2horizon,
y reduce the boost? the answer is simple, the car is not yet ready for that boost for daily use. my stock side mount intercooler still attach on it. so meaning the EBC will actually help to close and open to actuator base on the boost we set, rite? i wondering y my hks evc4 now not able to help to increase the boost base on my setting :(
hehehe...i also know the wastegate is the ultimate solution, but budget is a blocking point and other is it seem not worth for my current small turbo now.:smokin:
Well, most of the time.. Boost controller is used to increase the boost from minimum. cause there are amount of solenoid valves(depending on models) to leak the pressure to the actuator...
So, by installing that it may not be able to reduce the boost pressure. In rder to rduce the boost prssure, it's either to play around with the actuator rod or maybe change the actuator mod actuator with lower boost rate since it's not like waste gate, can change spring.
at least, that's what I inderstand about boost controller.
I agree with speed2horizon's statement. Just get a wastegate bro.
38mm is more than enough already. Tial & turbosmart is pretty good.
Hi, adding a wastegate would be a cost, before that, must we have a customized header for that particular wastegate?:hmmmm:
Not necessary a header. U can either mod your existing exhaust manifold. Just add on a pipe n flange for wastegate. Or u can leave your exhaust manifold and mod/get the downpipe before the turbine. But that depends on the type n brand of the turbo you are having...
Bump: Btw, if you are using mitsu's engine the custom banana nowadays are cheap and affordable.
Just safe some money and get a GOOD wastegate no matter what turbo u using... alot ppl using the same wastegate for years eventhough they upgrade everything else in the car... Just my 2 cents. :biggrin:
Thanks for the information bro. I'll have to start hunting...:love:
Thats so true.. save some money, buy a good one.. if possible a brand new lah.. Me having a very bad luck with actuator oledi also..
Bro.. can understand ur situation when facing with boost problem. Me worse... having problem with turbo also...
Finally everything settles....
bro,
what about zap wastegate..?
any experience..?
Bump: bro,
any experience..?
Bro, what kind of bad luck you encountered?:hmmmm: I am so interested to know...:love:
most probably faulty, cannot maintain boost etc... common thing after using actuator for long time....
BUY A wastegate! :)
About Zapp wastegate I can't comment much.. never used it nor know anybody using it....
What I do know is many ppl including myself using Tial... You won't go wrong there... :biggrin:
BUY A wastegate! :)
It's either going to be the diaphragm nocor, leaks or the spring lossen it's strength.
Is that what i am having now?
I can retain boost to only 0.8 bar, no matter how i adjust my manual boost controller, maximum at 0.8 bar. Other than that, i feel that turbine spools up not as fast as before. Might it be the gate stucked open? :hmmmm:
Thank you so much for replies made. :love:
