[WT Ask] About my Strange Boost Problem
szeeonn
to all sifu,
i set my GSR Turbo @ 1.2
so when i Full pedal , Turbo only Reach 1.2 for 1 Sec
After that automatic Dropped to 1.0 , 0.8 , 0.5 Slowly
Sems like the higher i Rev , the Boost drop faster
Normally , Turbo should maintain @ the Certain Boost when full pedal
I DID Not Release my pedal at all, keep on Revving
my Turbo Spec : TD04 , with Original Wastegate Actuator
thanks ^^
wow bro , so fast open a new thread?? as i told u, i have read a thread in zth about comparison between ori and fake tial wastegate, fake 1 will giv problem like urs, but since ur wastegate is ori, i will only consider leaking, if not leaking, maybe u should check ur ori wastegate too, scare condemn already..... just my small noob opinion.... do correct me if i m wrong
---------- Post added at 10:34 PM ---------- 6 hour anti-bump limit - Previous post was at 10:31 PM ----------
and also bro, from the info i get from zth,stock gsr only boost between 0.6-0.8, how come u can boost till 1.2 with out change ur stock wastegate?
peter: no prob wan using ori actuator..i'm also boosting 1.2bar ma..
szeeonn: i think u better check ur actuator..if rosak then it's time to use external w/gate ade..lol
try to pinjam ori bov from ur frens and see whether it solves ur prob, if it doesn't then try changing another actuator..
i think it was because of boost creep..
means the wastegate not releasing enough air when exceed pre-set boost...
u still maintain std boost or use any boost controller???
i changed to Jasma boost controller
if my piping is ok , means Actuator problem ?
if actuator problem , i cant get High boost AT ALL Right ? Now i can get high boost for 1 sec
